Deletes a path from the specified RSVP-TE LSP.
| lsp_name | Specifies a name for the RSVP-TE LSP. |
| path_name | Specifies a name for the path to be deleted from the RSVP-TE LSP. |
| any | Configures the specified LSP to use any path. |
| all | Deletes all added paths from the specified RSVP-TE LSP. |
N/A.
This command deletes a path from the specified RSVP-TE LSP. All the added paths can be deleted by specifying the all keyword. If the active path is deleted, then one of the other configured paths becomes the active path for the LSP. If there are no other defined paths, then the LSP is marked down and cannot be used to forward IP or VPN traffic.
The following command deletes the path called through-knightsbridge for the LSP london:
configure mpls rsvp-te lsp london delete path through-knightsbridge
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
